Please help with component cable audio issue
NewHome › Forums › OSSC, OSSC Pro and DExx-vd isl › OSSC – Discussion and support › Please help with component cable audio issue
  • #17716
    AirZonk
      I have had my OSSC for a weeks now and I am very pleased with the way it works with my Neo Geo AES and Atari Jaguar using Scart cables. However, I am having a problem with my NTSC Game Cube and Wii using component cables. When these systems are hooked up to the OSSC directly they work perfectly fine. Since I have more than one system using component cable I thought I would use a component switch rather than switching cables all the time. I used a manual switching JVC component switch that I had from many years ago. The picture works fine, but there is no audio when using the JVC switch. Would a powered component switch make a difference? Or is there some other way to get these systems hooked up without switching the cables around every time?
      #17722
        It’s possible it’s just the audio support in your switch that has gone bad; I don’t think it has anything to do with it being unpowered.
        If you’d like to get a new switch, you may want to look into a gcompsw when orders for them reopen. Alternatively, ShinyBow has a few models, but they’re more expensive.
