Possible x2 incompatibility problem
NewHome › Forums › OSSC, OSSC Pro and DExx-vd isl › OSSC – Discussion and support › Possible x2 incompatibility problem
  • #21057
    Lake
      I just bought an OSSC.
      I have a SNES (pal version) and a MegaDrive with a pal/ntsc/ntscJ mode selector.
      My television is a philips model 32pfl8605h.
      I read in the wiki that default line doubling is expected to work with any television,
      but I was surprised to see “video format not supported” on my TV when I tried playing with
      the MegaDrive in ntsc/ntscj format.
      This is the format that is being displayed on the ossc:
      YPrPb 262p
      15.55Khz 59.36Hz
      With the selector switched to PAL, the television has no problems.
      The SNES also has no problems as the video format is different.
      My question is: is it normal that my television doesn’t support the
      supposedly universal line doubling format?
      Might there be something wrong with my modded MD?
      Thanks in advance.
      #21071
        I had a similar TV model before which would handle a modded SNES in NTSC mode no problem (59.53Hz), so maybe that’s about the limit for vertical refresh rate. I think you might have crossed the tolerance level for vertical refresh with that modded MegaDrive.
        A solution would be to get a Dual Frequency Oscillator, to output correct clock speed for NTSC.
        #21072
          I remember encountering a Philips TV that was actually more compatible in line triple, so you should definitely give that a go too.
          #21074
          Lake
            I’m gonna ask a very, very stupid question now but..
            There’s no way to set line triple without the remote controller, right? ^^;
            #21075
              Right, I had forgotten about that, lol. Had noted it in my own initial report. 🙂
              Yes, you need a remote to access the menu to set Lx3.
