Power supply advice
- This topic has 3 replies, 2 voices, and was last updated May 11, 2018 at 1:15 AM by .
NewHome › Forums › OSSC, OSSC Pro and DExx-vd isl › OSSC – Discussion and support › Power supply advice
Hi everyone,
I’ve ordered an OSSC, but unfortunately when I ordered PSUs weren’t available in store.
Can anyone recommend a safe substitute part? I don’t want to risk breaking it with an incorrect supply, but I’m desperate to use my OSSC ??
“You require a unit that outputs DC 5V with at least 1 Amp. The tip must be 2.1 x 5.5mm and centre positive.”
Here’s one that’s UL and CE listed. I’m guessing you’re probably concerned about a cheap chinese power supply nuking the OSSC. The UL and CE listing provides some level of confidence. Others might have better “known good” suggestions, I just found this with a quick search.
https://www.amazon.com/ZIUMIER-Adapter-Regulated-Switching-Transformer/dp/B073JBRTH2
Thank you no affinity, I’ve got my OSSC up and running ??
Glad to hear it! And now I know where to get a backup. 🙂
