Problem sega master system 1 PAL
NewHome › Forums › OSSC, OSSC Pro and DExx-vd isl › OSSC – Discussion and support › Problem sega master system 1 PAL
- This topic has 20 replies, 6 voices, and was last updated May 18, 2019 at 10:22 AM by
Nodoka75.
August 24, 2017 at 12:36 PM #14731
Hello,
I have a problem with my Sega Master System 1 PAL. The OSSC v1.6 does not display any video signals.
The problem is only with this console.Bonjour,
j’ai un problème avec ma Sega Master System 1 PAL. l’OSSC v1.6 n’affiche aucun signal vidéo.
Le problème est uniquement avec cette console.August 24, 2017 at 11:55 PM #14739What is the read out on the LCD on the OSSC and what does it say when you press the Info button?
August 25, 2017 at 8:45 AM #14746It displays Vmod: 1536x240L LO: 1560 VSM: 0
thanks
August 25, 2017 at 9:10 AM #14748So you are using Lx5 mode. Does it work with Lx2, x3, x4?
Is the sync stable?August 25, 2017 at 10:01 AM #14750No it does not work either.
August 25, 2017 at 10:26 AM #14751If you set maximum brightness to mask and increase horizontal or vertical mask then does it display the mask?
http://junkerhq.net/xrgb/index.php?title=OSSC#Horizontal_mask
August 25, 2017 at 10:37 AM #14752No, there is nothing on the screen, the TV shows “no signal”
August 25, 2017 at 12:35 PM #14755You need to give us more info if we are to help you…
Do you have stable sync – green LED light, and the linecount, horizontal/vertical refresh is displayed without problems? What cable do you use, how is it wired? Can you confirm it works when connected directly to a TV?August 25, 2017 at 1:23 PM #14756No sync (green LED off) The cable used and the official RGB cable (PAL console sold with an RGB cable) The console works perfectly on the TV without the OSSC. The console is connected directly to the OSSC during testing.
August 25, 2017 at 2:21 PM #14757What is the read out on the LCD without the info button pressed?
AV1: RGBS ???p
xx.xxKhz xx.xxHz
Please let me know these numbers and are they stable?
August 25, 2017 at 4:15 PM #14762vmod: 1600×1200 LO: 1250 VSM: 0
edit:
I just checked, if I press info, it gives me the characteristics of the previous console that was plugged into the OSSC.August 27, 2017 at 11:50 AM #14785No not the info from the information page the standard readout on the OSSC LCD:-
AV1: RGBS ???p
??.??Khz ??.??Hz
May 17, 2019 at 4:21 PM #26240Hello all, I’m a new OSSC user! So far I’ve been quite pleased with the results with my various systems. Unfortunately, I’m unable to get any signal from both of my Master System consoles (Model 1 and 2, PAL).
Readout on the OSSC LCD: AV1: RGBS – NO SYNC
Info: Prof.9 1600×240Both systems work great on a CRT TV.
Any idea?
Thank you for your help.
May 17, 2019 at 5:05 PM #26241If it’s a french Master System, with the french official 3085 cable (it came with all french SMS, 1, 2, and Megadrive One), unsolder one pin of R19 inside the 3085.
May 17, 2019 at 5:17 PM #26242Thank you for your quick reply!
It is indeed a french Master System. What is the goal of removing R19? Is this for the sole purpose of having it work with the OSSC? Will it prevent it to work as before in any way?
