Problem sega master system 1 PAL
NewHome Forums OSSC, OSSC Pro and DExx-vd isl OSSC – Discussion and support Problem sega master system 1 PAL
Viewing 6 posts - 16 through 21 (of 21 total)
  • #26243
    Nexus45
      As I have two scart cables I did remove R19 in one of them, it does work perfectly! Thank you again! Still wondering what this really does though.
      #26244
      paulb_nl
        It seems removing the resistor would just change the sync voltage.
        Try changing Analog sync Vth in Sync options instead.
        #26245
        Nexus45
          Well that works too! Starting from 191 mV and upwards. Should I set the lowest value compatible or set it higher?
          #26246
          paulb_nl
            Yea set it at the lowest value that keeps a stable sync.
            #26249
            Nexus45
              Alright. Thank you all for your quick answers and working solutions.
              #26250
              Nodoka75
                @nexus45 As a bonus, your 3085 cable with R19 removed is now compatible with japanese Megadrive 1 (All model 1 in theory) ^^
                @paulb_nl
                Nice! I didn’t knew that there is an option in the OSSC menu for this purpose.
