Problems after firmware update
NewHome › Forums › OSSC, OSSC Pro and DExx-vd isl › OSSC – Discussion and support › Problems after firmware update
  • #17528
    FiveWob
      Finally came round to updating the firmware from 0.67 to 0.79, but now the only screen im getting with my PAL 1chip02 SNES and French N64 RGB mod is the test pattern. Spent the last hour fiddling with settings but no luck. Any idea whats going on?
      #17554
        Did you try doing a settings reset?
        #17574
        FiveWob
          Yeah still the same
          #17610
            What’s the LCD say when you switch to AV1? No Sync?
            #17616
            FiveWob
              Haha nah i was being an idiot. I wasnt even flicking it to AV1 in the first place! Just got so used to it automatically switching to a detected input from the old firmware. Sorry about that, and thanks for you help.
