Problems with ossc's lcd display, now broken :/
NewHome › Forums › OSSC, OSSC Pro and DExx-vd isl › OSSC – Discussion and support › Problems with ossc's lcd display, now broken :/
  • #24986
    JoNKaBiCLem
      Hi everyone !
      I bought an ossc in sept 2018. I had issues with the lcd screen very soon : The display was fading, like no contrast at all, the text on it was slitghly disappearing. But the backlight was OK. I had to push gently on the screen or make little tap on it and it was reappearing and then disappearing again. Problems were worse and worse so today, I decided to look at it more precisely and try to fix it myself (which i shouldn’t). Of course it went wrong and i accidentally broke the lcd screen…
      I don’t know if there is any waranty on the ossc but in my case, pretty sure it will not work :/
      It seems to me that a replacement with an equivalent screen doesn’t need incredible soldering skills, so what are the lcd modules compatibles ?
      If anyone can help me please ?
      I tweeted to @VGPerfection, just in case…
      I’ll post this message also in the “DIY KIT SUPPORT” section of the forum.
      #24990
        Sounds like it was one or more bad solder joints.
        Use the Contact Us form, linked in the main navigation, to get in touch with BuckoA51.
        #24991
        JoNKaBiCLem
          Thanks for the advice !
          #24992
            The LCD on the OSSC is an off the shelf component – Newhaven Display NHD-C0216CZ-FSW-FBW-3V3
            Here’s the display on Mouser UK – https://www.mouser.co.uk/ProductDetail/763-C0216CZ-FSWFBW3V
            If you purchased your OSSC in September 2018 it’s under warranty and this will be repaired or replaced free of charge for you if you e-mail in.
