PS2 and Xbox original hooked up with a OSSC.
NewHome Forums OSSC, OSSC Pro and DExx-vd isl OSSC – Discussion and support PS2 and Xbox original hooked up with a OSSC.
  • #53963
    Nick_NG66
      Hi all,
      I own a Kaico OSSC 1.6 and want to connect my PS2 through the scart input and my Xbox original through the component input of the OSSC so I have both consoles connected to one monitor. What would be the downfalls of connecting my PS2 through the scart input?
      Also thinking of getting a used surround receiver which I can use to connect both consoles. Will need one with video upscaling capabilities.
      Looking for a good solution to connect both consoles to one monitor. Anyone have some thoughts on what the best solution will be?
      #53973
        No downside since the OSSC can accept all signal types on the SCART input.
        I’d avoid a receiver with upscaling as this tends to be fairly limited and definitely not optimised for videogames.
        #54145
        Nick_NG66
          Hi. A bit late reaction from me!
          Thanks for answering my question. Are there any downsides on using a PS2 with a RGB scart connection?
          #54168
