PS2 color banding
- This topic has 2 replies, 2 voices, and was last updated September 3, 2018 at 4:58 PM by .
NewHome › Forums › OSSC, OSSC Pro and DExx-vd isl › OSSC – Discussion and support › PS2 color banding
I have a question concerning PS2 with OSSC. I’ve noticed the colors are off. I’m not referring to the RGB vs Component setting. It’s like the color depth is wrong, similar to playing a PC game on 16 bit (back when that was a thing). If I connect to the Framemeister it doesn’t do this. Colors are correct. Is there an OSSC setting that affects color depth? I’ve tested with line2x and 4x. Thanks
OSSC processes in full 4:4:4 with no sub-sampling. May be worth trying your TV on full range rather than limited.
Tested that and it made no difference. Also tested a different PS2 and different RGB cables. No difference. They all show terrible color banding as if the color depth is too low
