PS2, OSSC and Atomos Ninja V?
  • #26475
    TheFriendlyBroski
      Has anyone had any luck using any device by Atomos to try and capture gameplay via the OSSC? I’ve had no luck!
      Is it possible to capture PS2 gameplay via an OSSC & an Atomos Ninja V? My current setup consists of an OSSC & PS2 which is connected via SCART, the OSSC is then connected via a HDMI 2.0 cable into the Ninja V and then another one back into the TV.
      I am doing anything wrong here or is the OSSC not able to gel nicely with the Atomos? Could this change in the future?
      Any help would be grand!
      #26476
        I’ve never heard of those capture devices but it is common that many capture cards will reject off-spec signals (BlackMagic are the absolute worst for this!).
        If you can find one cheaply, adding a secondary scaler to the output of OSSC, such as a DVDO, will help improve compatibility.
        #26482
        TheFriendlyBroski
          Would using another scaler not add lag? I’m unaware of the con’s when adding extra devices on top of each other.
          #26484
            You can expect a scaler to add at least 1 frame of lag, but that doesn’t matter if you’re only adding it to make it compatible with your capture device.
            If you’re worried about lag using your capture device’s loop-out, add a video splitter earlier in the chain. If you have display that can take the analogue RGBS/RGsB from the PS2, toss in a SCART splitter (or something like the current gscartsw, which will rewrite RGsB to RGBS and make those format switches easier to manage); or, if you’re using a display with HDMI input, get an HDMI splitter (this thing, per this recommendation).
            #26533
            TheFriendlyBroski
              Thanks for the link! Very much appreciate it.
              I forgot I already own a HDMI splitter, so I’m hoping I can get it working.
              #56437
              Nickandre
                Any dice here? My Ninja V doesn’t like the signal straight out of the OSSC.
                #56479
                  Does it support 480p input and display even the ossc test pattern on power-on?
