Replacement F1 Fuse
- This topic has 3 replies, 2 voices, and was last updated March 20, 2019 at 4:14 AM by .
NewHome › Forums › OSSC, OSSC Pro and DExx-vd isl › OSSC – Discussion and support › Replacement F1 Fuse
A couple weeks ago I accidentally plugged in the wrong power supply and blew my fuse. For now I jumped it with wire and can still use it. Where can I buy the replacement F1 fuse? Im in the USA.
Thanks for the reply! This doesnt look like the original on the board, sso you sure this one will work? @Morpheus_79
It doesn’t look like the original because it’s the wrong picture. But it’s definitely the correct fuse:
https://github.com/marqs85/ossc_pcb/blob/v1.6/bom/bom_full.xls?raw=true
It’s the same used for the OSSC 1.5 and therefore listed in its BOM too:
https://www.niksula.hut.fi/~mhiienka/ossc/diy-v1.5/bom_pcb1p5-diy.xlsx
