Resolution Problem
  • #23079
    Jbot91
      I don’t know how many others are having this problem but I can’t seem to get the OSSC to just take 480i and then double that same with 240p. I keep getting Resolutions of 525i or 565i just a bunch of random 5XXi or for 240p its 2XXp. I don’t know if I can fix this or not just wondering really.
      #23080
        The OSSC defaults to displaying number of lines, where NTSC has 525 lines, 480 visible, per frame and PAL has 625 lines, 576 visible, per frame; so, when you see 525i/p for 480i/p content respectively, or 262p/263p for 240p content, those are correct.
        If that number is instead jumping around and not any of these, you probably have some other problem, like unstable sync. Specifically which console(s) are you having trouble with?
