Hi, ive read it but that didnt answer my question is there supposed to be two leds on all the time when operating?
I expect so but if you have any others in stock a quick test would help.
If you long press the blue filter button when your done playing lets say the larger green led goes out completely if console is off but the small yellow one stays on, so i assune the small yellow led just shows power input?
Its not mentioned in the manual i guess because it pretty much plug and play its not worth mentioning but unless mines different from every other one holding down the filter button when your done seems to turn off input completely.
Ta
P
