Rotate OSSC LCD 180 to allow for inverted mounting
NewHome › Forums › OSSC, OSSC Pro and DExx-vd isl › OSSC – Feature Requests › Rotate OSSC LCD 180 to allow for inverted mounting
  • #25477
    Sqwrly
      I would like to request the ability to rotate the LCD on the OSSC by 180 degrees so it can be mounted it upside down. I use wire shelving racks and would like it mount it upside down on the bottom of a shelf.
      Thanks
      #25478
      philenotfound
        I don’t think that’s possible, the character set in the LCD seems hardcoded, so you would have to do a custom character set… I believe there are not enough custom characters available.
        #25486
          As a potential alternative, mount it upright where you want it, with the power switch on, and use a different power switch upstream, such as a surge protector or PDU.
          #25487
          Sqwrly
            Thanks for the replies. I will likely go that route as I have a PDU in my rack I just wanted to save that for other stuff.
