Screen-burn issue?
  • #21899
    JoeTheUseless
      Hi there when i have my ossc on a pause screen for a long period of time the screen burns the image onto my display it goes away after a few mins but still very annoying it happened to my 42inch LG HDTV and computer monitor
      Is there a way to stop this
      thanks
      #21901
      AtlasShrugged80
        How long are we talking? What about just turning off the display while you have it on pause?
        #21905
          and which console were you using at the time?
          #21906
          GameJon
            LG often use IPS panels that are prone to image retention – it’s not “burn in” (as it’s not permanent) but there’s little you can do about it
            #21908
            JoeTheUseless
              Hi there it was the PlayStation one it seems to temporarily retain the image i think i had the OSSC in x4 but i can’t remember honestly.
              It seems to happen very quickly which worry’s me is there any power saving features in the OSSC? i think i might have to set up TV to go off after a short period of time but i’m not sure how long i should leave it !. the image burned after an hour and a half 🙁
              Luckily it just went away on its own i was worried though at the time it was permanent. I should have read the manual properly specifically page 8 which states this can happen 🙂
              Please excuse my grammar i never was good at English at school XD
              Thanks
              Joe
              #21913
              Galdelico
                Out of curiosity, which game were you playing?
                #21932
                  Yeah i don’t think you will do any permanent damage with progressive content, interlace is another matter.
