Scrolling video noise
- This topic has 2 replies, 2 voices, and was last updated June 26, 2019 at 3:30 PM by .
NewHome › Forums › OSSC, OSSC Pro and DExx-vd isl › OSSC – Discussion and support › Scrolling video noise
I just used my OSSC after it had been left alone for a little over a month, only to find weird noise scrolling up the screen. It doesn’t show up when I plug my SNES straight into my TV, and it’s still there with my PS2, so it’s definitely not the consoles’ fault.
Here’s a video of the problem.
I’m pretty sure it’s just the power adaptor, but I’d like to know if anyone has had a similar issue, other possible causes, or any other stuff that I should know.
Thanks.
Turns out it wasn’t the power adaptor at fault, it was the extension lead. Problem solved.
This kind of noise is also often caused by failing power supplies on retro consoles, or cheap replacements.
