SNES PAL – quiet hum / buzz after powering down console
NewHome › Forums › Repairs and Upgrades › SNES PAL – quiet hum / buzz after powering down console
  • #10696
    cachaito
      Hello, recently I bought a SNES PAL (version 1 chip) with AC Adapter NES002 EU. What worries me is after the power is turned off, I hear (from the TV speakers) buzz for about 15 seconds which eventually disappears. Console is plugged to TV with good quality SCART cable from Retro Gaming Cables. Another thing is that after playing game, power down console and remove the power cord, when power for one second, the red light is on.
      Maybe my power supply is broken? What do you think?
      Thank you for any help.
      #10710
        Sounds like a capacitor issue, have you opened the console and checked for any signs of bad caps?
        #10917
        cachaito
          Hi BuckoA51! Sorry for late response. I’ve opened console and it looks like brand new. Unfortunately I got no skills/ knowledge to spot and to check signs of bad caps 🙁
          I recently bought a new Power Supply for Nintendo NES and SNES from Retro Game Supply but had no time to check it.
          #10958
            How did the new PSU work out?
            Bad capacitors, well if it’s gone really bad it will be bulging out or even leaking, if it’s just slightly bad that’s harder to spot.
