Supergun for OSSC?
NewHome › Forums › OSSC, OSSC Pro and DExx-vd isl › OSSC – Discussion and support › Supergun for OSSC?
- This topic has 8 replies, 4 voices, and was last updated September 20, 2018 at 5:10 PM by
videogameperfectionrocks.
September 12, 2018 at 1:10 PM #23138
Is there a supergun known to work with the OSSC? HAS is supposed to be the best but currently unavailable. I only need RGB out and separate audio out.
September 12, 2018 at 5:01 PM #23141Someone can correct me if I’m wrong, but the OSSC should be able to take anything that’s SCART-compliant; so, if your supergun outputs audio and video within the ranges defined by the SCART spec, then the OSSC should be fine.
The only supergun that I would probably recommend against using is that Windy Gaming (Windy City Gaming? I don’t remember; sorry) one that had an unlabeled switch that let you toggle between line-level and amplified audio on the SCART port (WHY?! There is no reason to put amplified audio on SCART), and people ended up unknowingly feeding way-out-of-spec amplified audio into their gscart switches and blowing an IC or something.
September 12, 2018 at 5:31 PM #23143I’m a little gun shy because my CBOX CMVS fried my OSSC. 🙁
September 15, 2018 at 9:57 PM #23163Sorry to jump in on your post but I was looking for this same info.
I’m thinking about getting the Retroelectronik Supergun and was wondering if it was compatible. I don’t want to invest in the OSSC and then fry it with the supergun.
September 17, 2018 at 12:43 AM #23165No problem keyvisuals. The comments here say the Retroelectronik doesn’t attenuate RGBS properly:
The Windy Gaming or MAK Strike superguns are the best choices currently from what I can gather. The former has a fan and no audio output separate from the RGB port. The latter has a voltage spike issue but still seems like the best choice overall.
September 17, 2018 at 10:08 PM #23182Anonymous
I used a retroelektronic. It worked well, but with interference in the image. Many have reported various quality-related issues with their RE’s, and the seller does not respond to support requests. I didn’t have any quality issues other than the interference showing up in the video, but just be warned.
I’m now using a MAK Strike, and it works great. Feature rich, good price point, and no interference in the video output.
September 17, 2018 at 11:28 PM #23183That voltage spike hasn’t given you any trouble? Do you use the built in power switch to turn it on?
September 20, 2018 at 5:01 PM #23198Anonymous
If you’re asking me, I’ve got a HAPP arcade PSU wired directly to the terminal blocks of the MAK Strike. I don’t use the MAK’s built-in power switch, but rather the on-off switch of a surge protector that the HAPP PSU is plugged in to.
September 20, 2018 at 5:10 PM #23199I’m told that’s the correct way around the voltage spike issue.
