Hello,
I am trying to interface my american Commodore PET 4032 to the OSSC, and it won’t work with the same home made cable from user port to VGA that does works with several multiscan monitors I have, CRT, LCD and even a Plasma display. The signal is TTL pure monochrome with independent 20Khz Horizontal 60Hz Vertical sync.
Is detecting a 20Khz signal, but it won’t render anything, I tried to play with several options.
I saw in tech specs that 15Khz, 25Khz and 31Khz are supported, please support 20Khz as well, or even better, continuous refresh range, some computers like an Acorn are capable of generating any sync range.
Thanks!
