The ossc-v1.20 beta firmware seems to have some issues?
NewHome › Forums › OSSC, OSSC Pro and DExx-vd isl › OSSC – Discussion and support › The ossc-v1.20 beta firmware seems to have some issues?
  • #68051
    liuszuping
      Hello everyone, I successfully ran ossc_1p20_beta.jic (v1.20) on the OSSC CLASS.
      It seems there are a few small issues with the remote control:
      1. The v1.20 beta firmware appears to have added several new remote control buttons:
      • SHMASK_MODE+
      • SHMASK_MODE-
      • SHMASK_INT+
      • SHMASK_INT-
      1. However, when pressing SHMASK_INT+ / SHMASK_INT- during use, the OSD and OSSC show no response. After that, the OSD and all other remote control buttons stop working.
      2. The PHASE-/+ HOTKEY option in the menu, whether set to ON or OFF, does not allow the remote control’s Samp.phase -/+ buttons to directly adjust the phase as in previous firmware versions.
      Are these known issues?
      Also, have the profiles been modified so that each profile becomes a separate .bin file, stored directly on the FAT32 SD card?
      #68072
        These are now fixed in the release version.
        #68076
        liuszuping
          thank you…
