Use case question: 720p@120>1080p@120 via OSSC Pro possible?
NewHome › Forums › OSSC, OSSC Pro and DExx-vd isl › OSSC – Discussion and support › Use case question: 720p@120>1080p@120 via OSSC Pro possible?
  • #60825
    Abwezi
      I have a unique usecase with a TV I want to attempt to use with an HDFury x4 to output and view 3D on it. The TV is an LG C1 and it supports 120hz but I’m discovering it does not appear to support 720p@120hz, it does support 1080p@120 and 1440p@120 natively though. Would an OSSC Pro be capable of making this conversion?
      #60828
        720p@120hz -> 1080p@120 is supported but currently no 3D metadata is passed thru.
        #60829
        Abwezi
          Interesting. The Hdfury would process the 3d metadata from the source and produce the emitter signal to the glasses I only wonder if any delay how small from the OSSC Pro being further down the chain would cause could impact the sync of the glasses, but maybe I will test it I’ll consider buying it seems the cheapest option at this point actually
