VGA Scaling/sizing options?
  • #21732
    Angelworks
      So I have this ancient Compaq Prolinea 5133 that I fixed up and play MS-Dos games on. It works quite well with the ossc, but in 320×200 it’s zoomed in too much so that the left/right and top/bottom parts of the screen are chopped off. Firmware .81 it got better – but the top and bottom are still cut off. I can at least read the left/right parts of the screen (where the ms-dos command line starts).
      At 640×480, 800×600 etc it looks perfect – perfect 4:3.
      Is there any way to adjust this? Or is this mainly intended for progressive vga output like the dreamcast or xbox?
      #21757
        Having all edges of the image lopped off sounds like an overscan issue with your display, but it also sounds weird that it wouldn’t happen with 640×480 or 800×600. Is the OSSC actually outputting 320×200 or is it linedoubling and putting it in a 640×480 frame? Are you using the new 640×400 preset?
        #21761
        Angelworks
          Yeah it looks like an overscan problem, but keep in mind all the PC games I’ve ever played usually have a border around them to handle that – so I dunno.
          The 640×400 preset seems to do nothing on AV3 :(.
          #21767
            What are you using for a display? (Make, model)
            #21793
            Angelworks
              Its a 55″ TCL 55C807 – but I don’t think that is the issue – the output looks similar on the Startech USB-3 capture device, but I have to admit I have no clue at this point.
              The startech device thinks the output is 720×480 though. Now that I think about it – I could put a sample clip onto youtube of the issue I’m seeing if that helps.
