White LCD of “death”.. but not permanent
NewHome › Forums › OSSC, OSSC Pro and DExx-vd isl › OSSC – Discussion and support › White LCD of “death”.. but not permanent
Viewing 1 post (of 1 total)
  • #35428
    legosnapshot
      I bought an OSSC 1.5 (with audio board) back in early 2017 and it’s been running like a champ.. until a few weeks ago. Recently, it will turn on and the LCD will be completely white. If I flash it via JTAG with a USB Blaster, I’m able to recover the device and everything works properly (for a short while). I’m using the “official” power supply and a DVI to HDMI adapter for output. I’m using the YPbPr inputs and getting video from a Carby Component cable (Gamecube).
      Has anyone else seen this behavior? I’m comfortable servicing the unit, if anyone has any ideas.
      I did notice one thing — it sometimes happens if I lift the unit or push the component connectors quickly while the board is powered on, which suggests maybe a cold solder joint?
      Any help is appreciated!
