Add a PC Engine controller to your Bliss-Box 4-Play or Gamer-Pro adapter. Note, this is the smaller type connector, found on the Turbo Duo, PC-Engine DUO CD, CoreGrafx and SuperGrafx.
Also compatible with the Low-Latency ports on the BlisSTer v2 and with SNAC accessories (Serial Native Accessory Converter).
Always check the compatibility list if purchasing a cable for a specific controller.
If you need an adapter for the Turbografx pad, which uses a larger DIN plug, click here.
