Add a PC TurboGrafx-16 controller to your Bliss-Box 4-Play or Gamer-Pro adapter. Note, this is the larger type connector, found on the TurboGrafx consoles sold in the USA.
Also compatible with the Low-Latency ports on the BlisSTer v2 and with SNAC accessories (Serial Native Accessory Converter).
Always check the compatibility list if purchasing a cable for a specific controller.
If you need an adapter for the PC Engine pad, which uses a smaller DIN plug, click here.
