Connect your Extron Crosspoint or similar commercial grade RGB switch to any SCART compatible display or upscaler. This cable has 4 BNC input connectors and one phoenix audio stereo connector wired for audio output (unbalanced). The cable outputs to a male SCART plug and is 90cm/35.5 inches in length.
This cable also includes a 460ohm resistor on the sync output to properly attenuate the output. This is necessary in order to be compatible with the Extron Crosspoint as the Crosspoint internally boosts and attenuates sync to TTL levels.
