Fully “consolise” your Sega Game Gear by adding this fantastic controller port upgrade from Pxlmod technologies.
The perfect companion to our McWill Game Gear screen/RGB out upgrade, this upgrade will allow you to use any Megadrive/Genesis controller with your Game Gear. When used with the McWill kit, you can play your Game Gear games on the big screen using a comfortable, console controller.
Finally get the ultimate, 100% authentic hardware experience with your Game Gear, it’s like the best console upgrade Sega never released!
Unlike the controller port upgrades you may find for sale from our competitors, our units are 100% authentic and sourced from the original designer. Unlike many of the competing bootleg products they also feature full ESD protection. This means you won’t accidentally fry the modification by connecting or disconnecting your controller with the power on, or just by sheer bad luck (we still recommend turning the power off when connecting a controller just to be on the safe side).
The kit contains the main PCB, QSB PCB and D-sub/controller port connector.
Your classic console deserves the best, so get the best, with the Pxlmod Sega Game Gear Controller!
Fitting Instructions
Please note that installing this upgrade requires soldering skills. Do NOT order this kit until you have read ALL of the fitting instructions and feel confident with carrying out the installation. Some community based support may be available in our forums but we CANNOT offer technical support with DIY fittings nor can we give refunds on components that have been damaged or destroyed due to incorrect use or failed installation attempts.
Fitting instructions can be found here.
If you need a professional fitting service for this part, click here.
Installation of the McWill RGB out upgrade is not necessary to use this mod although it is of limited use without it. Please ensure your console has been re-capped before installing this mod.
