I am having blackout/sysnc issues with my OSSC
NewHome › Forums › OSSC, OSSC Pro and DExx-vd isl › OSSC – Discussion and support › I am having blackout/sysnc issues with my OSSC
- This topic has 21 replies, 5 voices, and was last updated March 9, 2020 at 12:13 PM by
Wildcardsoldier.
March 1, 2020 at 3:12 PM #35888
I got an OSSC a few weeks ago and every time I play for 20-40 minutes, the screen goes black for a few seconds an then returns to normal. How do I fix this issue?
March 1, 2020 at 3:53 PM #35889Hello,
it would be necessary to describe on which console (pal, ntsc, switched model, 50 or 60hz), which game (and its region), is it in “action” or during a passage in a menu or a loading screen, including does it have a single cut or several then ….?
OSSC default settings or have you changed a value?
What cable (rgb / scart, yuv /?) Between the console and the ossc …
In short without additional information as much to play the lottery;)March 1, 2020 at 5:52 PM #35895it is on 6OHZ NTSC xbox and ps2 using component cables and it’s in “action” when i’m playing my NTSC copies of JSRF and Raw Danger. it’s during passthrough mode, too.
March 2, 2020 at 11:33 PM #35947Which TV? Does the LED blink on the OSSC?
March 3, 2020 at 2:32 AM #35951it’s a haier HD tv and it doesn’t blink.
March 3, 2020 at 3:42 PM #35961I’ve never heard of that brand unfortunately. We have a handful of reports of this (literally 2 or 3) it’s proving extremely difficult to track down (even using same ossc and same display as a customer I can’t replicate it).
Have you tried other consoles, e.g 240p machines see if they have issues?
March 3, 2020 at 4:54 PM #35963I have been having this issue with component based consoles like the ps2 and xbox, using the VGA port for my switch and PC work perfectly and output 60hz exactly but the xbox/ps2 usually output around 59.86-59.92.
March 4, 2020 at 1:20 AM #35975Ok so I reset my settings and it didnt syncout when I was playing for 40 minutes so I hope that worked.
March 4, 2020 at 10:32 AM #35987Please let us know.
March 5, 2020 at 2:09 AM #36015I’m sorry. it worked fine yesterday with 2 different games across 40-50 minutes each but now it is now repeating again. should i make a more detail thread?
March 5, 2020 at 3:55 PM #36030Hey, I have the same issue. Can play for 20-40mins and the screen goes black for a few seconds and returns to normal. Using NTSC SNES jr (RGB modded), RGB scart cable and Asus vg248qe monitor. Live gamer extreme capture card from avermedia to capture my image when streaming. It does the same thing whether connected or not to the capture card.
March 5, 2020 at 5:04 PM #36034SNES could be the jitter issue, is your console dejitterd?
March 5, 2020 at 9:50 PM #36044Nah its not. Just strange it keeps happening every now and then, sometimes more often, sometimes less.
March 5, 2020 at 10:03 PM #36046That’s a different issue to the OP I would imagine, it’s unclear why some users struggle with 480p content.
March 6, 2020 at 12:27 AM #36049I made every video setting into passthrou mode and it’s still goes black randomly.
