Intermittent signal with OSSC.
NewHome › Forums › OSSC, OSSC Pro and DExx-vd isl › OSSC – Discussion and support › Intermittent signal with OSSC.
  • #48513
    JikissGamer
      I just recently bought an OSSC and I’m trying to capture an old PC using a Datapath E1S capture card and the signal constantly flickers on and off. This is the second OSSC that had this issue because the first one I had did the same thing and I bought a second one to avoid the issue and it had the same exact issue right out of the box. I looked at the capture card compatibility forum on here and it says the Datapath is compatible, and my first OSSC worked great for a few months. I updated to the latest firmware with no luck either. If anyone has an idea on how to fix this I would greatly appreciate it. I am sure it is something I’m doing wrong since it happens with both of my units.
      #48514
      JikissGamer
        I tried swapping the cables out for some different ones and I tried several different PCs but it’s still flickering.
        #48539
          What do you mean by flickering? Does the OSSC lose sync? (E.g. red led flash and ”no sync” or rapid change in input signal info?)
          What kind of PC output are you trying to display (resolution/Hz)?
          #48542
          JikissGamer
            Yes it loses sync and the red light flashes when the screen goes blank for a quick second. It happens repeatedly, mostly in bursts of two sync losses at a time. I am capturing my Pentium computer with through the VGA port of its 3dfx Voodoo card, and running DOS which is 640×480 at 70Hz. I also should mention I have an active VGA splitter in the chain, one to the OSSC and another to a monitor.
            #48578
              This guy seems to have a similar problem.
              Voodoo pc problem
              Unfortunately he didn’t get any feedback so it seems unresolved.
