Need some help with an Atari STE, OSSC and a Cam Link
NewHome › Forums › OSSC, OSSC Pro and DExx-vd isl › OSSC – Discussion and support › Need some help with an Atari STE, OSSC and a Cam Link
Viewing 1 post (of 1 total)
  • #20868
    STNoob
      Hopefully someone can help? The OSSC has 0.80a firmware.
      I’ve got an Atari STE with a UBE VGA connector, and the ST is set to hi-res. I haven’t played about with low/med res yet.
      The Atari ST puts out the following:-
                                     High        Low/Medium
                                     640x400     320x200 / 640x200
      Vertical refresh rate          72 Hz       50 or 60 Hz       (Since I'm in a Pal region that's 50Hz for me)
      Horizontal refresh rate        31.5 Khz    15.75 Khz
      With a bit of messing about, with the settings said here https://videogameperfection.com/forums/topic/atari-130xe-with-vbxe-upgrade/page/2/
      So basically, with V Active 400, Allow Upsample 2x and adjust backporch, I can get a picture in nearly 16×9 on my monitor, but I’d rather have 4:3.
      The problem is, that the Cam Link just keeps complaining that the input picture isn’t supported. Mainly because it’s seems to think it’s getting 800p72.
      The OSSC’s LCD reports AV3: RGBHV 501p 35.80kHz 71.47Hz.
      Is there anything I can maybe try to force this to work?
