OSSC Audio Output too loud
Viewing 15 posts - 1 through 15 (of 20 total)
  • #46213
    husan93
      Hi guys,
      so recently I noticed while playing N64 that the sound clips in certain loud scenes. However, the audio from the 3.5mm jack is fine.
      My OSSC was ordered from here and has the audio expansion with DVI.
      I don’t know if the audio is too loud with other consoles, but I would guess so. Is it possible to adjust the volume of the digital audio output in any way?
      #46218
      Fnnrqwin
        Go to the audio options in the settings menu and adjust Pre-ADC gain. Some consoles are just much louder than others.
        #46394
        husan93
          Finally got around to try it out.
          Adjusting the Pre-ADC gain had no effect at all. It didn’t matter if I set it louder or quieter. I dindn’t hear any difference and the audio clipped like before.
          #46422
            Update to the latest firmware, there were some audio fixes a while back.
            #46426
            husan93
              I have the current firmware (0.88a) on my OSSC.
              I always keep my OSSC up-to-date. 🙂
              #46457
                You got me stumped then 🙁
                #69467
                osscboy
                  ~Sorry for the necro bump~
                  Hey husan93, I know, this thread is 5 years old by now…and maybe you aren‘t even frequenting this board anymore, but I figured it‘s worth a shot:
                  I think I got the same problem that you describe when downscaling to my CRT TV:
                  Sound, more specifically bass clips after a certain loudness/deepness threshold. The pre-gain setting of the Ossc Pro is already set to -12, but regardless of where it‘s at, I couldnt discern any difference, whether it be -12, 0 or +12.
                  Also tried turning my PC way down and my TV up to compensate but that didn‘t solve it either: Clipping persited and humming was added.
                  So I figured maybe the speakers of the TV really are broken instead, but connecting my original PS2 disproved that, it still sounds excellent.
                  So maybe the OSSC Pro might be outputting too loudly in general, the 3,5mm jack of the Extra AV extension is broken, its the Mr Pi VGA to Scart cable, I couldn‘t figure it out yet.
                  So my question, did you ever solve this problem? Or anyone else for that matter?
                  #69468
                    We do now know that the N64 outputs audio that is too loud/over amplified by default as this caused an issue recently with the Morph, so the issue really is a design fault in the N64 but of course that’s not much help knowing that now not like Nintendo are going to fix it.
                    I don’t know why the gain settings aren’t seeming to affect it but I do know we solved the issue on the Morph by simply adding an inline 3.5mm volume control to the N64s output – https://videogameperfection.com/products/3-5mm-volume-control/
                    That’s easy to do with s-video or composite not so easy if you’re using SCART however we have had a solution for SCART for some time there were just delays getting it to fab, I’ll update here when it’s available.
                    #69760
                    osscboy
                      Having now tried such a 3,5mm volume control, I have to report that that didn’t solve the problem. As soon as a turn up the volume on my TV, it starts to clip again. Guess I have to wait for the Update and hope that finally does it. With update you mean the new Extra AV Extension that also supports Composite and SVideo outputs, I presume?
                      #69761
                        Did you place the volume control before the input on the OSSC Pro or after the output of the OSSC Pro?
                        #69762
                        osscboy
                          I placed it between the Extension and the VGA to Scart cable. Since my PC is connected via HDMI and thats also how the sound is transported to the OSSC Pro there wasn’t a way to place the volume control anywhere else.
                          • This reply was modified 5 months, 2 weeks ago by osscboy.
                          #69765
                            I can’t explain this behaviour then. I’ll ask Markus to take a look.
                            #69766
                            osscboy
                              Ya ok, thank you. 🙂
                              #69767
                                Dumb question but just in case, you have tried simply reducing the volume on the PC, correct?
                                Edit – sorry NM I saw above you said you did.
                                • This reply was modified 5 months, 2 weeks ago by BuckoA51.
                                #69771
                                Kekstier
                                  When you emulating N64 via PC, maybe one trick is perfect:
                                  • you have to set the “loudness equalization” to ON (under sound effects) in windows 10/11 OR set for N64-core of emulator the volume control to  minimal gain (mostly min. -12 dB),
                                  • set in the emulator the audio synchronisation to ON, switch between the audio driver “WASAPI” or “Windows Mixer”
                                  • set in OSSC Pro the parameter “Pre-ADC gain” to -12 dB, set the audio source for HDMI (AV4) to AV4 (digital), to make sure, that the sound come from HDMI output of your PC OR when you go via other input, set the 3,5 mm jack correct under “3.5mm jack assign” in audio settings of ossc pro,
                                  • set the volume control of your CRT to the wished level
