Was the firmware ever updated since your description doesn’t clearly state whether the issue occurred already before update was initiated?
<p>I purchased the unit, and it was running just fine on the .90 firmware. After I completed the one-wire mod, the device still booted normally. Once I confirmed everything was working properly, I formatted the SD card with the latest firmware to initiate the upgrade process through the menu. However, when I inserted the newly formatted SD card and booted the unit, the OSSC powered on with just a blank white LCD screen—showing no text and no output over HDMI. I physically checked for any shorted pins, and everything looks fine. I suspect there may be a short in the SD card holder that corrupted the flash.</p>
Yes, it sounds like the flash has got corrupted somehow. You could loan/acquire USB Blaster to update it via JTAG. Some of the cheap alternatives should be sufficient but I’d keep an eye on the reviews.
