PAL PS1, XBO and Line4X
  • #25501
    KBABZ
      Hiya! Another slight issue with the OSSC that I was hoping there’d be a solution to. I’m currently having my PSone (the slim one, PAL) running to my OSSC via a SCART cable through which it then goes into my launch Xbox One so my TV and capture card can accept it. I’d prefer to use the 4X mode as that offers the sharpest pixels, however the bottom of the picture is cut off slightly. I’ve tried raising the picture using settings from the Line X Tips and Tweaks page, but none of the settings actually change what the picture looks like (which is odd because it did on my PS2). Any possible solutions?
      #25518
      KBABZ
        I take it there’s no solution to this?
        #25519
          Have you tried the instructions to get 288p/576i line4x in a 1080p frame in the Tips & Tweaks: Lx3, Lx4, Lx5 modes thread?
          #25520
          KBABZ
            Yeah I have, nothing seems to work. It seems that when trying to adjust 240p content through the XBO, nothing moves or changes or anything.
            I will say though that this effect varies between games. I just went through my admittedly small PS1 library and compared between what my XBO was showing and what I can see on my PSone LCD screen. Here’s what I found:
            8 lines cut: Spyro 2*, Spyro 3*
            3-4 lines cut: Crash 1, Crash 2, Crash Bash, Croc 2, Emperor’s New Groove*, Grand Turismo 2, MediEvil, MediEvil 2*, Monsters Inc.,
            1-2 lines cut: Crash 3
            Unaffected: CTR, Spyro 1*
            *In these games I can move the screen up from the default position, so these games aren’t a problem.
