Programming Chunghop remote
NewHome › Forums › OSSC, OSSC Pro and DExx-vd isl › OSSC – Discussion and support › Programming Chunghop remote
- This topic has 21 replies, 4 voices, and was last updated April 19, 2019 at 2:40 AM by
kruuth.
April 21, 2018 at 11:31 PM #21020
Hi folks. I have a chunghop L336 remote here. Does anyone know the code for each device? JunkerHQ lists Yamaha for the DVD and the Receiver and Toshiba for the TV but mine didn’t come with the codes to put in.
April 22, 2018 at 12:19 AM #21021Where did you buy your L336 remote? If you bought it from VGP it should be preprogrammed for usage with the OSSC and should work right out of the box. If you bought a “blank” one from anywhere else, you’ll need to program it by yourself. But there aren’t any codes to put directly into the remote. You HAVE to have a remote (or an IR transmitter which is able to act as a remote) the L336 can learn from.
April 22, 2018 at 2:31 AM #21028My wife was visiting family in China and had access to them for almost nothing. She brought back one in the box.
April 22, 2018 at 6:02 AM #21031You’ll have to program it yourself then. But as i said: since it’s a learning (not a universal) remote, it does NOT come with any preprogrammed Manufacturer codes inside, you can access by simply inputting a numeric code! You’ll have to teach the remote by sending all the IR signals to it, it has to learn.
April 22, 2018 at 12:38 PM #21034Crap. That’d a mess. Does that mean every don’t remote is manually configured for ossc? What should I do here?
April 22, 2018 at 1:53 PM #21035The profile of an already programmed L336 can be transferred to a “blank” L336… so there’s no need to configure all buttons for multiple remotes multiple times.
There are a couple of things you can do to get your L336 working with your OSSC:
- Test every remote you or your friends and family own for its compatibility with the OSSC. Simply turn your OSSC on and press some buttons of the remote you want to test pointing at the direction of your OSSC. If the green LED of the OSSC flashes while a button is pressed, you’ve found a suitable remote. Now you can copy the button commands from this remote to your L336 and configure your OSSC for the usage with it like its described here:
http://junkerhq.net/xrgb/index.php?title=OSSC#Remote_control_setup
power cycle the OSSC while holding BTN1 on the OSSC’s PCB. A target function name (e.g. “MENU”) will then be displayed on the OSCC’s LCD screen. Press the corresponding key on the remote control, if the OSSC receives the code correctly you will be prompted to confirm the new code. Press the same key again to confirm, or BTN0 on the OSSC’s PCB to go to the previous key. If you press BTN0 when configuring the first key, the default keymaps will be loaded.
Once all remote control keys/buttons are programmed, the new keymap will be saved and the OSSC will return to normal operation.[/quote]
- If you can’t find a working remote, you could buy a cheap universal remote with lots of preprogrammed manufacturer codes to choose from. After you’ve found a working code you can use it directly with your OSSC or to program your L336.
- You can buy (or build) a USB infrared transmitter (like the Irdroid USB transmitter, the USB IR toy, or similar) and use WinLIRC to send the right commands to your L336.
April 23, 2018 at 7:30 PM #21055SO far I have no remotes.
I do though, have access to my neighbor’s Harmony remote. Can I use that to program the L336?
April 23, 2018 at 9:15 PM #21058Of course. The Logitech Harmony is a universal remote… just not a cheap one 😉 .
April 24, 2018 at 12:28 AM #21062Ok…What do I need to do in order to do that? I set up the device like in the instructions for Harmony, but it doesn’t seem to work.
April 24, 2018 at 8:20 AM #21070After you’ve sent the NEC Profile to the Harmony: does the green LED on your OSSC flash every time you press a button on the Harmony?
April 24, 2018 at 1:44 PM #21078No it does not flash. I think I might have selected the wrong one. This is a Harmony 520 remote. It is asking for a specific TV.
EDIT: Ok, I reflashed the remote, and now the little green light does flash. Now that it’s doing that, can I use that to flash the Chunghop?
April 24, 2018 at 3:54 PM #21080You can use the Harmony to teach the Chunghop all of its commands.
April 24, 2018 at 4:09 PM #21081Ah ok. I thought that it was a case where I could transfer them all at once. So I need to do it one at a time?
April 24, 2018 at 4:20 PM #21082Afaik: transfering multiple button commands at once to a L336 is only possible from another L336.
April 24, 2018 at 10:28 PM #21091That’s a pain.
I see the little green LED going on and off, but nothing happens, no matter what I press on the remote. Is there a particular key that would do something? I press menu and nothing happens.
