This module replaces the fragile plastic buttons on the side of the CPS-2 A-Board (“TEST” “UP” “DOWN”). Furthermore, it has LEDs which indicate when a button is pressed!
Installation instructions
Installing the buttons requires soldering skills, please ensure you are confident enough carrying out the work yourself before ordering. Please do not purchase this part unless you are confident with a soldering iron. While community support may be available in our forum, we cannot give technical support with DIY installations, nor can we offer refunds or compensation for parts damaged due to bad/incorrect DIY installations.
Basic instructions:-
1. Solder wires from Button Module to A-Board
2. Insert Button Module into slot in plastic case
3. Close case
A video tutorial for the installation is coming soon.
