This kit will convert a CPS2 digital kit into a CPS3 digital kit. It’s basically this product (click here) but without the FPGA board. It is for customers who already purchased a CPS2 digital upgrade but now want to fit it to CPS3 hardware.
The quick solder kit Includes 2 PCB’s, a ribbon cable, coax cables, wire and resistors. In other words, everything you need for a CPS3 digital installation. No male or female headers are included because these are sold with the FPGA kits. If you want to purchase a complete kit, click here.
The base kit contains a flex cable that is 5cm in length, which is suitable for standard installations. If you are doing a custom installation for a specific cabinet or case, you can change to a longer flex cable of either 10cm or 20cm by using the drop down menu above.
Fitting Instructions
Please note that installing this modification requires soldering skills. Do NOT order this kit until you have read ALL of the fitting instructions and feel confident with carrying out the installation. Some community based support may be available in our forums but we CANNOT offer technical support with DIY fittings nor can we give refunds on components that have been damaged or destroyed due to incorrect use or failed installation attempts.
Fitting instructions can be found here.
If you need a professional fitting service for this part, click here.
Capcom, CP System II and CP System III are trademarks of Capcom Co. Ltd, CPS3 digital AV interface is NOT an official Capcom product.
