All switches shipped as of 17/02/25 have the the audio upgrade pre-installed, this fixes all issues with distorted sound on Wii, GameCube etc. Firmware 2.1 is also pre-installed, this firmware has the following new features:-
- User selectable pin 16 signal voltage – Allows for full compatibility with older CRT TVs that require appropriate signal voltage on SCART pin 16
- Faster start up time
- Automatic over-the-air updates for any future firmware
- LCD Menu allowing configuration of advanced features without the need for a Wi-FI connection
The GamesCare 8 in 2 out Smart RGB SCART Switch is an affordable yet feature packed and very high quality RGB SCART switching solution. Ideal for connecting multiple consoles to multiple SCART TVs, scalers or capture devices. The switch comes with a total of 8 fully wired RGB SCART inputs and 2 RGB SCART outputs. Signal quality is preserved while switching, with no detectable degradation of either video or audio signals.
The switch can change inputs automatically once a connected device is powered, or can be manually controlled by a push button on the unit or by PC or smartphone using the devices built in Wi-Fi connection.
The GamesCare Smart SCART Switch is fully automatic, compact and expandable. Add on expansion modules will be available on our store soon.
Features:
- Smart functionality, allows the switch to be configured and operated from a smartphone or computer
- Built in display screen to show configured input name, Wi-Fi settings and additional information
- 8 SCART Inputs
- 2 SCART outputs (both outputs mirror the current input)
- Expansion connector can add additional 8 inputs
- Discrete Stereo audio output
- Compatible with all SCART signals and formats
- Interlink capability (connect additional ports with GamesCare expansion)
- Crafted video circuit keeps signal clean and free of interference
Included with each Smart SCART Switch is a multi-region 12 volt power supply unit (please do not connect this PSU to an OSSC, RetroTINK or Morph device).
Downloads
GC RGB SWITCH Getting Started
GC RGB SWITCH Mobile App Manual
