A 3D printed enclosure for the Legacy AV In expansion card for the OSSC Pro (non RF version). Printed on an industrial 3D printer for the best possible finish.
Keep the card free of dust and debris with this 3D printed case, printed in black to match the OSSC Pro’s case. Installation is easy, simply disconnect the Legacy AV In card from your OSSC Pro, place it in the bottom part of the case, then snap the top part of the case on and reattach it to the Pro.
Optionally, you can screw the board into place using any screw between 6mm and 10mm deep (not supplied). As this is a 3D print the holes are not pre-threaded and you may want to use a self tapping screw or wood screw.
Case only – OSSC Pro and Legacy AV are shown for illustration purposes only and are NOT included with this product.
This is an open source design. If you have your own 3D printer you can download and print the file yourself by visiting the page here. The Legacy AV In case is sold on VGP with permission of the original designer.
Mark Ferris –
Unlike the previous reviewer I had little problem fitting the board and the case is perfectly aligned with the ossc pro.
fierman –
Top lid broke in pieces after trying to fit. Brittle and won’t fit. Better print your own, because these are absolute crap.
