A quality, shielded and grounded RGB SCART cable for use with the McWill Game Gear LCD and RGB out mod kits.
Fully compatible with 15khz CRTs and upscalers. Can be used with most SCART equipped HDTVs too. Carries both audio and video.
Note – Does not support 31khz modes. Due to how the video output is designed on the McWill Game Gear screens, 31Khz RGBC output is not normally available. If you wish to use your McWill modded Game Gear with an OSSC, for instance, we recommend you use a standard VGA to VGA cable instead. These cables are widely available online.
