Upgrade the cooling on your Morph4K unit with this fan kit. Once this kit is installed, any 40x40x10mm fan can be used to help airflow and cooling inside the unit. The Noctua NF-A4x10 5V (3 Pin variant) is recommended by PixelFX.
If you regularly use the SDR to HDR conversion and your Morph is on a shelf or in a cupboard with poor ventilation then fitting a fan is recommended.
A 2 pin through hole connector must be soldered onto the bottom side of the morph PCB. More details are available on the Morph4k Wiki.
- Kit includes:
- 3x M2 inserts
- 3x M2 screws
- 1x MJF printed mount
- 1x 2 pin connector
