We now stock the IPS V1 Revision 3 version of this fantastic screen kit! Please study the fitting instructions at the bottom of the page carefully before you decide to order. Installing the kit in the Lynx I requires soldering. Lynx II is solder free but requires a steady hand.
Breathe new life into your classic Atari Lynx hand held with this cutting edge LCD replacement. Replacing the dated original LCD with this new, vibrant IPS model will make playing Lynx games a lot more fun, thanks to increased brightness, contrast, picture sharpness and improved battery life.
These replacement LCDs are the best currently on the market and have been specifically engineered for the Atari Lynx. Both Lynx I and Lynx II are supported. Unlike the Game Gear, the native resolution of the Lynx is a great fit for these new screens and no complex scaling is required. Apart from a tiny change in the pixel aspect ratio, the screens are a perfect replacement.
Why choose BennVenn screens over the competition?
- Superior IPS Panel – Rich warm colours, deep blacks, amazing viewing angles, super efficient
- Single PCB can support Lynx I and Lynx II consoles
- VGA out to play on your TV/Monitor/etc (see below for more details)
- Brightness control via the contrast wheel
- Optional On-screen Low Battery indicator
- Options for Vertical/Horizontal/No scanlines
- Double the battery runtime compared any other kit (& will not crash your game as batteries get low or glitch your controls)
- No soldering required for Lynx II, minimal soldering required for Lynx I
- 3D printed install frame by Atari Gamer takes the guesswork out of alignment when installing.
- Only one component needs removing from the PCB (Lynx II) or one wire cut (Lynx I) vs dozens with other kits
VGA output – Due to popular demand, these kits now offer a VGA output option. Note however the kits do not include a VGA connector. It is up to the end user to decide what connector to use. BennVenn recommends a magnetic VGA cable that will allow the VGA output to be connected without a case modification. Click here for more details.
What is included in the IPS Kit?
- Universal LynxI/II screen driver PCB
- Custom manufactured BennVenn IPS Screen
- 3d Printed installation frame (Lynx1 or Lynx2 type)
- Solderless install ribbon (Included in LynxII Kit only)
- Capacitive touch module (To enable scanlines/VGA mode on Lynx I)
Fitting Instructions
Please study the fitting instructions carefully and only order if you’re completely confident that you can carry out the mod. We cannot offer refunds for mods damaged due to incorrect installation, nor can we offer technical support for installation of this mod. Please make sure your Lynx is in good working order before installing this mod.
Full install guides are available courtesy of our friends at AtariGamer.
Compatible with ALL motherboard variants* (That we have tested! LynxI/LynxII/LynxI Japanese/Early LynxII)
Ezio Raddi –
Magnificent product, great build quality and easy to install.
It looks very good.
Very recommendable seller.
