A female SCART to 9 pin D-sub style connector with 2 x female audio breakout cables. Includes a built in sync stripper. The cable is designed to connect RGB SCART equipment to the affordable Extron 202 Rxi RGB interfaces.
Extron Interfaces are useful for a number of things (click here if you’re not familiar with them), from acting as simple sync combiners to picture adjustment and alignment. They are frequently available on the second hand market, but some models have a less common D-sub 9 video connection, rather than the now standard D-sub 15 (VGA) connector. These models tend to be more affordable, because, until now at least, it was harder to get the required cables to use them.
The cables are tested with Extron 202Rxi but they should work with other Extron interfaces too as long as they feature the less common 9 pin D-sub style input.
