Sorry - Not currently available
All repair/modification work is carried out subject to our terms and conditions. Once you have placed your order, details of where to ship your hardware will be sent to your e-mail address. Prices do NOT include return postage. To estimate return postage we recommend Parcel2Go. Parcels will be returned by Royal Mail or UPS only.
Have the capacitors in your Sega Master System console renewed/replaced with high quality replacements. A capacitor is an electrical component that stores electrical energy. In older machines, these components can wear out and sometimes leak, in some instances leaking corrosive fluids onto the consoles motherboard. If you see signs of capacitors bulging or starting to leak on your consoles motherboard, we recommend getting them replaced as soon as possible.
Note that replacing capacitors is time consuming and is not guaranteed to improve or fix any issues you are having with your console. We recommend purchasing this service only if you believe the capacitors on your console are starting to degrade. If you decide to replace the capacitors in your console, please understand we cannot give refunds after the service is carried out, even if replacing the capacitors does not have the desired effect.
