Modernise your classic Game Boy Color console and extend battery life by adding this handy USB charger kit from JOVEMA Technologies/Mcwill, the same innovator who brought you the fantastic Game Gear and Atari Lynx replacement screens.
Once installed, you can recharge your Game Boy console* using any USB 5 Volt charger with a Mini USB connector. Juice up your little handheld while working on your PC, or use a USB phone charger. No more dealing with AA batteries or antiquated, bulky recharge packs.
The kit contains one USB charger PCB and pin header.
* Note – Requires 1 x 14500 rechargeable battery. We recommend LiPo batteries with a protection circuit. Due to WEEE regulations we are unable to supply batteries with this kit. Not all 14500 batteries are rechargeable, please double check before using/charging!
Safe to use with flash-carts – but please remember the Gameboy will not indicate when the battery charge is low, so be careful if swapping/re-flashing games on the go.
Fitting instructions
For fitting instructions, see this link. Do NOT order this kit until you have read ALL of the fitting instructions and feel confident with carrying out the installation. Some community based support may be available in our forums but we CANNOT offer technical support with DIY fittings nor can we give refunds on components that have been damaged or destroyed due to incorrect use or failed installation attempts.
A fitting service for this part is coming soon.
Game Boy and Game Boy Colour/Color are trademarks of Nintendo Co., Ltd. USB Charger for Gameboy Color is NOT an official Nintendo product.
