Note, this is a complex, intricate upgrade. Please study the fitting instructions at the bottom of the page carefully before you decide to order.
Introducing revision 3 of BennVenn’s amazing HighDef, integer scaled IPS Game Gear screen kit. Breathe new life into your classic Sega Game Gear hand held with this dazzling new, cutting edge IPS LCD replacement. Replacing the dated original LCD with this new, vibrant model will make playing Game Gear games a lot more fun, thanks to increased brightness, contrast, picture sharpness and improved battery life. Furthermore, with the HDMI version of the kit, you can enjoy your Game Gear on the big screen too!
This is a premium replacement screen for your classic Sega Game Gear console with a superbly clean, perfectly scaled image that fits the native resolution of the console perfectly. There is no shimmer or tearing whatsoever. BennVenn sceens are the ONLY kits with no screen tearing on moving images!
Perfect scaling is not the only upgrade this new screen offers. You can now configure the advanced features of the screen using an on screen menu display. This menu allows you to adjust scanlines and post processing effects and configure scaling and output modes. Sega Master System games are also supported (using a suitable converter or flash cart). The screen also has extremely low power consumption, no more needing huge packs of AA batteries on those long journeys!
The kit comes with the following items:-
- Custom designed BennVenn HD (640×480) IPS panel
- Custom BennVenn VA0/1 driver circuit board (Now compatible with 315-5378 ASIC [Firmware V2.2])
- Touch module for on screen display (OSD)
- Digital video out (TMDS) (HDMI out version only)
- Wireless easy install ribbon
- 3D printed install frame
Fitting Instructions
Note, this is a complex, intricate upgrade. Please study the fitting instructions carefully and only order if you’re completely confident that you can carry out the upgrade. We cannot offer refunds for kits damaged due to incorrect installation, nor can we offer technical support for installation of this upgrade.
Please make sure your Game Gear is in good working order before installing this upgrade. If the existing LCD is faint or can only be seen at an angle, you must replace the systems capacitors, otherwise performance from the replacement LCD will not be satisfactory. There are various guides on-line on how to do this or we can perform the repair for you here.
Please note this kit is not compatible with Majesco Game Gear VA4 or VA5.
A fitting service for this upgrade will be available soon.
Still not convinced? Check this excellent video review from Macho Nacho productions:-
