Now your OSSC Pro can accept S-Video and composite video with this new expansion card! This add-on card will allow you to connect both composite video and S-Video directly to your OSSC Pro, allowing for many more older systems to be connected to the device without expensive and often invasive RGB mods.
This expansion card connects directly to the expansion port at the side of the OSSC Pro and provides 1 x composite video and 1 x S-Video input. Both inputs can be connected simultaneously without any adverse effects. To select an external input, press the EXT button on the remote (number 8) or open the Input Select menu and choose one of the inputs labelled “EXP_”.
Support for RF video connections is planned in a future revision of this card, the cards currently on sale do NOT support RF.
Support for composite and S-Video has been the most requested hardware feature since OSSC Pro launched, so this expansion card should prove extremely useful to many OSSC Pro owners!
