This is it! The ultimate 3DO RGB and 240p mod kit. These new kits from Black Dog Technology solve all the problems of our older boards and introduce a whole host of new features too.
Using a custom flex cable, this mod fits more neatly and securely in your classic console, eliminating the multiple wires of the older version. What’s more, you can now get perfect 240p output from your console consistently. No more flicking the 240p switch back and forth, with this kit your 3DO will always switch to 240p mode correctly, giving a sharp image. Want to leave your console in 240p mode all the time? No problem, unlike our previous mod you can now start the console in 240p mode too!
Issues with picture shift/centering have also been addressed, for a guaranteed perfect image every time.
Enjoy the ultimate high quality RGB output with your 3DO console with this DIY fit RGB upgrade kit. No more S-Video or composite, this mod is ideal for use with an OSSC or XRGB Mini and a must have for 3DO fans with HDTVs!
Fitting Instructions
For full fitting instructions, please visit the page here.
Note this is a complex modification which requires fine soldering skills, please familiarise yourself with the fitting instructions and do not order unless you are completely confident that you have the soldering skills necessary to install the board. While some community based support may be available in our forum, we cannot offer refunds for mods damaged due to incorrect installation, nor can we offer technical support for installation of this mod.
Please note that the late Panasonic FZ-10 and Goldstar GDO-202 model 3DO consoles contain the revised ANVIL video chip which does not output 24bit digital RGB and cannot be modded for analogue RGBS at this time. The only way to know for sure if your console has this particular chip is to open it and check.
If you need a fitting service for this part, click here.
