OSSC and ABT Scalers (VP30,50,Edge)
NewHome › Forums › OSSC, OSSC Pro and DExx-vd isl › OSSC – Discussion and support › OSSC and ABT Scalers (VP30,50,Edge)
- This topic has 71 replies, 21 voices, and was last updated August 30, 2020 at 7:57 PM by
BuckoA51.
June 6, 2016 at 5:23 PM #7484
In this thread you can discuss using the OSSC in combination with ABTs mid and high end scalers, such as the VP30, VP50, VP50 Pro and DVDO Edge/iScan Duo.
Here are our findings when using the unit with the VP50 Pro:-
https://videogameperfection.com/2016/06/06/ultimate-gaming-upscaler/
July 6, 2016 at 12:14 AM #7792480p Line double mode seems to be incompatible on the VP50 Pro. Will test DVDO Edge later. 480i Passthrough works great with VP50 Pro however.
July 25, 2016 at 7:05 PM #8150August 23, 2016 at 3:44 PM #8571Has anyone tested the OSSC x2/x3 480p double modes on an VP30 ?
I didnt want to go through the testing if someone has already tried it 🙂
September 3, 2016 at 4:11 PM #8721Hi guys,
Got a DVDO edge on its way from eBay. Am I right in thinking it can combine the audio from the OSSC into its HDMI output?Also any tips on its use, I’m mostly using 50hz PAL content hence the EDGE rather than a VP50.
Thanks!
October 12, 2016 at 9:06 PM #9084Sorry missed your post until now, yes the Edge can combine audio from OSSC and video into the same HDMI signal no problem. Edge also works with Pal linetriple, though we’d still recommend 60hz consoles wherever possible.
February 13, 2017 at 1:23 AM #11189Line x4 and Line X5 modes – Line x4 is confirmed working on the DVDO Edge green, not working on the 50 Pro.
Line X5 does not work on the 50 pro, may have issues on the Edge Green.It’s reported by other users to work on the VP50 though.Picture quality is very good on the Edge Green using either mode.
February 14, 2017 at 9:26 PM #11234Update – Line X5 mode DOES work on the 50 Pro.
For best results, use these settings in the OSSCs advanced timing options:-
H. Samplerate 2057
H. Backporch 255if you don’t change these settings you may get artefacts in the image.
Line x5 in 1080p mode will crop part of the image, that’s unavoidable.
March 16, 2017 at 1:40 PM #11848Has the OSSC been tested with the iscan HD/HD+ ?
While I’d rather get the vp50 it seems very hard to come by at a decent price.March 24, 2017 at 5:00 PM #12007I also recently got hold of a DVDO Edge.
Has anyone tried feeding it with Line X5 yet?
Does Line X4 work with both PAL & NTSC sources on the EDGE?
March 24, 2017 at 6:43 PM #12010I have an edge and get tearing with line X5 and it won’t accept x4 at all. Only tried it briefly though with a PAL md and haven’t put any effort into trouble shooting it yet. Looks great with line x3 though!
March 25, 2017 at 11:51 AM #12021I only tried NTSC sources, they seemed to work in 4x and 5x on the Edge. Same high input lag bug as with other resolutions though.
April 9, 2017 at 1:42 AM #12295I tested my equipment with Line 4X and 5x and this is what I got:
DVDO Edge + Sega MD II PAL: 4X No, 5X Yes
DVDO Edge + SNES PAL: 4X No, 5X Yes
DVDO Edge + N64 NTSC: 4X Yes, 5X YesDVDO iScan Duo + Sega MD II PAL: 4X No, 5X No (it shows a strange distorted image)
DVDO iScan Duo + SNES PAL: 4X No, 5X No (it shows a strange distorted image)
DVDO iScan Duo + N64 NTSC: 4X Yes, 5X No (it shows a strange distorted image)Which settings would you recommend me to tinker with, to make the 5X setting work with the iScan Duo? I’d much prefer to use the Duo and get rid of the Edge down the line.
April 14, 2017 at 2:41 AM #12386I know this is mostly OOP, but has anyone tried the OSSC with a Lumagen scaler? I have a Lumagen RadianceXD, a scaler that is superior to anything ABT has made ;), and I hope this would be a good combo that’s simpler to use than the XRGB-mini I’ve just sold.
April 15, 2017 at 12:05 AM #12401The ABT scalers are desirable here because of low lag, I believe the Lumagens have at least 2 frames of lag. PQ should be really good though.
