A fully shielded adapter that converts from the JP21 standard (common in Asia) to SCART (common in the rest of the world). This cable allows you to use JP21 RGB cables on the OSSC or Morph.
This is mostly for our customers in Asia, use of JP21 cables in Europe, America, Canada and the rest of the world is rare. You do NOT need this adapter just because you have some import consoles. You only need this adapter if you sourced your RGB cables from a supplier in Asia, such as Solaris Japan.
Want to convert SCART to JP21?, in that case you need this adapter.
