superegor.
May 5, 2020 at 12:27 PM #37534
I have a Panasonic TX-32LMD70A, it’s a pretty old TV but latency is really low (about 1 to 2 frames compared to a CRT; I split a signal to test), has really good blacks and sound quality is rich. I thought I’d share my findings here. I’ve tried the following consoles but haven’t had any success getting anything other than 2x working:
NTSC NES (TWRGB)
PAL N64 (TWRGB)
PAL SNESFollowing advice on the pinned “TIPS & TWEAKS” thread, I tried playing with v.active and v.bachpoch but I never get a picture. I read in my manual that HDMI port 1 can accept DVI, so I’ve set the OSSC to DVI but that hasn’t helped. I guess there’s no hope here but 2x (480p) does look pretty decent, I just wondered if I could get it looking even crisper and if getting 720p or 1080p would give even less lag.
May 6, 2020 at 12:18 PM #37565I got my hands on a Samsung LE32C530F1W(XXU) (another old TV) and with the same consoles listed in my previous post, 2x, 3x and 4x work on all of them without any tweaks, but 5x doesn’t. It’s interesting to see that 3x and 4x are a bit crisper but the jump from 1x to 2x is most dramatic; 6 feet away I probably couldn’t notice the difference between 2x and 4x, but I could 1x to 2x. This TV has about 3 or 4 frames of lag, the sound is tinny and has pretty bad motion blur.
May 6, 2020 at 4:56 PM #37579Console used: Sega Mega Drive 1
Paired with OSSCTV: Loewe Planus PL530 30″
Notes: This TV does not support HDMI inputs, only component or VGA. Using an HDMI to VGA/Component Converter did not work at all.
Reasons: Component Inputs do not support progressive scanning.
VGA is a direct 480p Signal ONLY needing 15Khz RGBs
Solution would be a SCART-VGA Upscaler/Transcoder that outputs 480p @ 15KhzMay 6, 2020 at 5:04 PM #37580VGA is a direct 480p Signal ONLY needing 15Khz RGBs
VGA is a 31khz signal not 15khz. The VGA standard does not have any 15khz modes at all, so I would think it was your VGA converter not working properly in this instance.
May 6, 2020 at 11:41 PM #37595I was testing the monitor of a friend.
This one has the most promising results so far.
In some games line doubling wasnt really noticeable at all but in others it made quite a difference.
I tried the The Legend of Zelda Collection because there are some old games on there as well like TLOZ NES/II Links Adventure/OOT.
Ocarina of Time was a huge difference and looked much better with Line4X.
Super Mario Galaxy 1,2 and Super Smash Bros. Brawl also looked better than before.
It wasnt really noticeable in Skyward Sword(probably because of the strange art style) and in the gamecube version of Need For Speed Hot Pursuit 2.Tested on Wii(PAL)
Samsung LS24F354FHUXEN:
_____________________
*24″ 1080P 60Hz Monitor
*Freesync240p/288p
Passthru: No
Line2X: Yes
Line3X: Yes
Line4X: Yes
Line5X: Yes480p/576p
Passthru: Yes
Line2X : Yes480i/576i
Passthru: No
Line2X: Yes
Line3X: Yes
Line4X: YesJune 20, 2020 at 12:04 AM #39085Just got my ossc. Thought i should contribute…
I’m using my Megadrive modded to 60hrt
My set is a LG 6300
3x work’s great
4x work’s great
5x work’s greatLoaded with firebands profiles.
Hope i could help this thread somehow…June 24, 2020 at 9:04 PM #39193has anyone ever tested one of these with an insignia (best buy budget brand) flatscreen TV? just bought an OSSC today and am nervous to find out whether 3x will work on this cheap a$$ TV of mine
July 11, 2020 at 10:19 AM #39690Seems my OP disappeared when trying to update it… Luckily I made a backup locally. Can you help restore the post Bucko?
August 16, 2020 at 8:54 PM #40710Hi !
Anyone know the compatibility level of Panasonic OLEDs like the TX55GZ950E ?
I want to buy an OSSC for Gamecube and PS1, and im afraid with compatiblity :'(
August 19, 2020 at 12:35 PM #40816It will probably be able to do Lx3 with tweaks, as reported for EZ950 and FZ950 models.
See the entries in OP.August 23, 2020 at 10:34 PM #40937Can anyone help? I bought an RGB modded N64 (JPN NTSC, model number NUS-001) which can play PAL games.
I can’t get it to display anything through my OSSC on my Samsung tv (Model UE55MU7070). I can get it to work through Line 2x on the Panasonic TV downstairs so I was wondering if I need to tinker with anything? Obviously I’ve given it a go but I can’t get it to work.
Thanks
August 25, 2020 at 8:57 PM #41005Do you see the test pattern on the Samsung? Reminds me of a post of a user with a Samsung using a ”one connect box”.
Also this is not a general support thread. 😉October 9, 2020 at 8:47 AM #41965TCL 50S535 will force as 16:9-ish aspect ratio across all native 4:3 content with no option of adjusting the screen.
2x, 3x, 4x worked with 480i content. Passthru mode results in a squished, horizonal image that is unplayable.
October 14, 2020 at 8:19 PM #42121That’s unfortunate. Did you try any 240p source or just 480i?
November 3, 2020 at 12:52 AM #42573ViewSonic Elite XG270QG
Tested with PS1, PS2, TW’s RGB modded N64 and Sega MegaDrive.
Only works properly at x3, but not at every optimized mode (PS1 256×240 only works at x2, for example). Passthrough and x2 don’t look good or it’s just 16:9. x4 and x5 got no signal.
In conclusion, not suitable at all for ossc, and it’s a shame because it’s such a good 1440p monitor for everything else.
